I can't see a downside mate as you haven't got an VW ECU. It is better value now than a year ago with the rates going our way for a change.
Modifying a std loom wouldn't be that bad but Ben makes good stuff IMO. What about having him ship in a couple of packages to minimise duty?
Just been measuring up the Scirocco engine bay.
The raintray will have to go, which will give the turbo and manifold more room.
If I remove the raintray I reckon I can get the brake booster and master cylinder, probably SEAT Ibiza ones in front of the driver. Then i can loose the vague and ugly linkage bar which takes up loads of room.
Also the previous owner has bought a brand new and massive radiator, but mounted it back too far. I can move it an inch or more forward using factory boltholes and give more room for the intake. Even if I move the radiator forward, I will still have heaps of room in front of it for a massive intercooler, without cutting up the front of the car.
I`m excited....
good, would be a shame to have to cut up the front bar and stuff, sleeper FTW!!
Loon, I don't know where you find the time.
This is a pretty fast moving project. Will be could to see it done.
As far as ECU's. I'd just throw a Microtech LT8X at it.
Far cheaper, easy install & by far more tunable on every level. Especially if you upgrade stuff later on.
You'd get out of it for less than $1600 tuned if you fit it yourself. Probably get a trade discount on the ECU too.
Also if your chasing an intercooler, I'd try & find one out of a Mitsubishi Evo3 or a Galant VR4. Will cost no more than $200 & are a very efficient intercooler will bugger all pressure drop, good size inlet & outlet's & are also fairly compact. Will easily fit in the front of a mk1 if you move the rad. back an 1".
Will easily support 400+hp.
I have had a couple of microtech cars and I hate the wasted fuel and crappy cold start system. The rocco is a nice car, I just wanna be able to turn the key and drive it. Not often, but FAST!
Head Bolts are torqued now, Timing belt is on and diesel side mount.
Have a couple of issues to sort out with the oil return to the sump and the different fittings on the G4 turbo and the AEB block.
Got a Clutch today. Will stick the gearbox on soon for a trial fitting.![]()
Hmmm your giving me inspiration for my mk2 scirocco, but i lack the funds so its a while off yet.. Hope to see this beast of yours all together for the nats! Nice work Matt![]()
