Page 9 of 33 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 324
Thread: My Scirocco Project
  1. #81
    Camden, Sydney
    Quote Originally Posted by WABIT View Post
    wow loon its finally getting started!!! cant wait to see this thing in may.....
    also what are you doing with the borbets??
    wabit
    Dont reckon it`ll be there in may. Thats 8 weeks away.
    THe Borbets are on the Caddy.
  2. #82
    **** 8 weeks!!! havent looked at it like that, i better get a move on!
    are you bringing the Caddy to Nats?
  3. #83
    Anyone got any bad or good points about a QPENG setup?
    I can't see a downside mate as you haven't got an VW ECU. It is better value now than a year ago with the rates going our way for a change.
    Modifying a std loom wouldn't be that bad but Ben makes good stuff IMO. What about having him ship in a couple of packages to minimise duty?
  4. #84
    Camden, Sydney
    Just been measuring up the Scirocco engine bay.
    The raintray will have to go, which will give the turbo and manifold more room.
    If I remove the raintray I reckon I can get the brake booster and master cylinder, probably SEAT Ibiza ones in front of the driver. Then i can loose the vague and ugly linkage bar which takes up loads of room.
    Also the previous owner has bought a brand new and massive radiator, but mounted it back too far. I can move it an inch or more forward using factory boltholes and give more room for the intake. Even if I move the radiator forward, I will still have heaps of room in front of it for a massive intercooler, without cutting up the front of the car.
    I`m excited....
  5. #85
    Jun 2007
    Eastern Suburbs Melbourne
    good, would be a shame to have to cut up the front bar and stuff, sleeper FTW!!
    i like volkswagens
  6. #86
    Loon, I don't know where you find the time.
    This is a pretty fast moving project. Will be could to see it done.
    As far as ECU's. I'd just throw a Microtech LT8X at it.
    Far cheaper, easy install & by far more tunable on every level. Especially if you upgrade stuff later on.
    You'd get out of it for less than $1600 tuned if you fit it yourself. Probably get a trade discount on the ECU too.
    Also if your chasing an intercooler, I'd try & find one out of a Mitsubishi Evo3 or a Galant VR4. Will cost no more than $200 & are a very efficient intercooler will bugger all pressure drop, good size inlet & outlet's & are also fairly compact. Will easily fit in the front of a mk1 if you move the rad. back an 1".
    Will easily support 400+hp.
  7. #87
    Camden, Sydney
    I have had a couple of microtech cars and I hate the wasted fuel and crappy cold start system. The rocco is a nice car, I just wanna be able to turn the key and drive it. Not often, but FAST!
    Head Bolts are torqued now, Timing belt is on and diesel side mount.
    Have a couple of issues to sort out with the oil return to the sump and the different fittings on the G4 turbo and the AEB block.
  8. #88
    That's fair enough.
    You really have to tune it yourself as they normally load a crappy cold start & cruise setting, but they normally get the full load setting's pretty good.
    Funny about that!
    Once there right, they can be pretty good though.
  9. #89
    Camden, Sydney
    Got a Clutch today. Will stick the gearbox on soon for a trial fitting.
  10. #90
    Jun 2006
    Orange NSW
    Hmmm your giving me inspiration for my mk2 scirocco, but i lack the funds so its a while off yet.. Hope to see this beast of yours all together for the nats! Nice work Matt
Similar Threads
  1. Random Scirocco in a field
    By Golf Loon in forum Scirocco
    Last Post: 31-12-2009, 04:53 PM
  2. Audi 90 Quattro 20V Project
    By type89 in forum The Audi Quarter
    Last Post: 28-09-2006, 10:36 PM
  3. Scirocco
    Last Post: 17-02-2006, 10:57 PM
