Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 111
Thread: Mk1 Scirocco- light Blue
  1. #61
    Jun 2007
    Eastern Suburbs Melbourne
    Looks good Glenn. I know already that there will be a few jealous bodies on this forum!
    i like volkswagens
  2. #62
    Perth. WA
    Quote Originally Posted by Hydro View Post
    it is a chrome [ or stainless ] covering that clips
    over the gutter. This may be a different gutter to yours.
    Glenn.
    Early Scirocco uses aluminium extrusion, very easy to bend out of shape, has a tiny slot in the rain gutter at each end for a dimple in the ali to clip into.
    Later versions use the clear plastic coated foil stuff, which with sun action goes brittle and yelows, usually falls apart trying to remove it. Held on with a black mastic stuff.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  3. #63
    Camden, Sydney
    Where will you put the rear number plate??
  4. #64
    Aug 2007
    Liverpool
    it hangs beneath the Bumper....already has a number plate light there - connected and working.
    Shame I cant get all the headlights to work.
    I ssuspect the fuses.
    Glenn....with Old Scirocco to replace old Beetle.
  5. #65
    Aug 2007
    Liverpool
    Overcast day.
    Still working on electrical and little annoying things.
    Pics........
  6. #66
    Aug 2007
    Liverpool
    pics....
  7. #67
    Aug 2007
    Liverpool
    pics....
  8. #68
    Aug 2007
    Liverpool
    more
    this is the aluminium gutter trim................
  9. #69
    Aug 2007
    Liverpool
    More gutter trim
    this one has been drilled at the ends where dimple was.
    Its sitting up a little bit due to paint.
  10. #70
    Aug 2007
    Liverpool
    the Sirocco sign on the rear needs the original number plate lights fitted in
    to give it that " Lairy night time " look.
    I was wondering if white neon strips would illuminate it better. Will try the lights first.
    Maybe a switch to flickering light could be fun - or good for braking.
