Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 111
Thread: Mk1 Scirocco- light Blue
  1. #41
    Aug 2007
    Liverpool
    Yes , thanks Grant.
    Glenn....with Old Scirocco to replace old Beetle.
  2. #42
    Jun 2007
    Eastern Suburbs Melbourne
    yea if you do spray 2pak, i'd hire a booth and full safety gear, that way the conditions are much more ideal and consistant for spraying 2pak (temp humidity etc) and safe
    i like volkswagens
  3. #43
    Perth. WA
    You will need to be extremely careful, Isocyanates are accumalitive material, once you have a reaction to exposure it is likely they will always be a continuing problem.
    "Safety alert on isocyanate sprays
    10 July 2009 Print this article Comments Share this article
    WORKSAFE Victoria has released a safety alert for woodworkers warning of the risk to health from spraying furniture with two-pack polyurethane paints and lacquers containing isocyanates.
    According to the safety alert, spraying generates a mist that may be inhaled and cause respiratory sensitisation and occupational asthma. Exposure to trace amounts of isocyanates can then trigger these symptoms once a person is sensitised, which means the person can no longer work with isocyanates.
    Organic solvents and thinners used to clean spray guns can also affect the central nervous system and various organs and can cause dermatitis.
    The risk can be eliminated or reduced by referring to the material safety data sheets for guidance on suitable controls, or using paints and lacquers that do not contain isocyanates.
    Other measures include using downdraft or side-draft spray booths to vent the fumes outside, locating open faced spray booths away from cross drafts, using an airless or high volume low pressure spray technique to minimise overspray, and using an airline respirator.
    Items should be placed on a turntable in an open faced booth, so the operator can rotate the items and direct the spray towards the extraction point. Freshly sprayed items should be kept in the booth until they are touch dry.
    Spray booth, respirator and airlines should be maintained regularly to ensure air quality, and there should be control of ignition sources in areas where flammable solvents are used or stored and within two metres of open faced booth "
    from
    http://www.safetowork.com.au/article...ys/489995.aspx
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  4. #44
    Jun 2007
    good work, keep us updated, and all the best for the final spray.
    i like volkswagens
  5. #45
    Aug 2007
    Liverpool
    Gettting progressed now.
  6. #46
    Perth. WA
    Looking good Glen, hit us up with some pics of the finished paint job ( clearcoated ).
    whatever you do, dont lose the clips that hold the trim around the rear quarter windows, there totally unobtainable from anywhere...
    Cheers,
    Grant...
  7. #47
    Aug 2007
    Liverpool
    Thanks Jarred and Grant.
    The clear is done now , but want to get some parts on to get better idea
    of " the look ".
    My Brother [ previous owner ] has some neat spoiler / skirt accent
    ideas which I will be painting today.
    Sort of break up the colour of the car but with accents to draw attention to
    these parts. Looking forward to how it looks.
    Have lots of wheel polishing and tyre blacking to do.
    Glenn
  8. #48
    Jun 2007
    that looks really good. congrats on getting it painted!
    I think taht's a really cool colour, always wanted to do a mk 1 that colour. Speaking of which, what colour is it?!
    i like volkswagens
  9. #49
    Aug 2007
    Liverpool
    it was so close to being Turquoise.........
    The colour is Moonstone Blue - Toyota.
    Very Metallic.
    In sunlight its " Silver ".
    I got bogged down on the bumpers today, I thought they were in excellent order.
    When unpacked - they were shocking. So too much time spent there.
    Spoke to Mathew at Camden GTI, getting brake upgrade tomorrow - hopefully.
    Glenn
  10. #50
    Aug 2007
    Liverpool
    Its got one of those Sirocco Signs on it like everyone has
    I could not find the screws or plugs that hold the Foam Rubber rear spoiler
    on.
    If any one knows what normally is used for this could they please tell me.????
    Glenn.
