Originally Posted by
Blue103TDIDSG
OK, went to Bunnings and they only had "Scotch" brand + some others I haven't heard of - no 3M
Spent an awfully long time going through all the types/brands etc
The best Scotch branded tape was about 1/2 kilo per metre
A "Perma" brand "Mounting" tape had a capacity of 20kg per metre but was a bit dearer - that's what I ran with - It's clear as well
Like chalk and cheese compared to the original tape.
Unfortunatley it was 20mm wide and I had to cut it in half width wise - took a bit but got there
Anything it touched it stuck to.
Covered pretty well all the underside of the foot rest
Didn't have any acetone so I used iso propyl alcohol to clean the plastic
Carefully positioned and pressed on - instant adhesion -
Don't think you could get it off if you wanted too !!! And that's with less than 50% of the bond strength
Just shows what garbage tape they use in the first place
Thanks again for the "heads up"
A lot of Scotch brand is actually 3M if you look carefully at the packaging
I bought this in Walmart in the USA but is available at Bunnings. Is identical to the 3M stuff I bought off 3M themselves
