You'll be fine with any of the European brands, like ATE, Textar, Zimmermann, etc.
RDA, DBA, etc will probably last longer, but it won't stop as good, and they'll be prone to warping.
Hi guys I have a 2012 Scirocco and I'm getting close to needing to replace the rotors.
Do my question is what have people done either aftermarket or is replacing them with stock rotors the way to go.
Cheers in advance
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Thanks mate, I'm coming from the JDM side so new to the European brands with lots to learn
Resident grumpy old fart
RDAs will probably let you down but DBA are a quality product. I'd get the 4000 series with a plain face.
Give Brakes Direct a call for options.
Otherwise, micksgarage.com has several brands including Mintex and delivery is only $25.
update with how you go please OP. specifically interested in how you go with squeak and brake dust.
Drop me a message if you need a quote on parts or replacement mate. Mostly used textar discs and found them comparable to OEM.
Just placed an order for the DBA2808S Street Series T2 Slotted Brake Rotor. $346 shipped to my door. I will probably install them myself.
I am due for my 60 000km service as well... so I will be quite light in the pocket by the end of next week lol
So you only replaced the rotors & not the pads? Possibly not a great idea.
haha no i just haven't bought the pads yet, just ordered the rotors today. Haven't decided on a set yet. I have used DBA with Ferodo performance pads before and really liked the price/performance as a combo. Ferodo seems to be hard to find online here in qld
