Originally Posted by
Arno_Scirocco
I am considering getting some 18's with semi slicks fitted and popping the current set of wheels in the garage.
Has anyone done this? Gone down an inch and increased the tire profile to 40? I think ride quality would be a bit nicer but i don't want to lose performance.
You're kidding, right? Losing performance with semi-slicks? They'll out corner any "sports" tyre of similar width.
And the sidewalls of semi-slicks are MUCH stiffer than normal tyres (which is why many semi-slicks are available in fairly tall profiles) so you'll almost certainly find the ride will worse. Plus they're noisy as anything and wear stupid fast.
But you'll gain performance in almost all respects except for fuel economy
Good to hear that you're ok, though and that the 'Roc came out pretty well
Resident grumpy old fart
