Clutch is Slipping - need replacement 24xxxk
Hi Guys,
So 24,000 km's and my clutch is on its way out, noticing when cold (70-85 degrees oil temp) in high gear (4,5,6) Heavy load when turbo kicks in my clutch is slipping, curious even with the stage 1, should this be expected? The slipping seems to be less evident after car is properly warmed up.
Seems strange with such low K's.
APR stage 1 with VWR intake,
Clutch is not usually covered by warranty as wear and tear item however it shouldn't be failing this young.. but happy to be told other wise.
Regards
2013 VW Scirocco R - Black
APR Tuned, VWR CAI, VWR Springs,
