Results 1 to 5 of 5
Thread: Brake Upgrade?
    Jan 2012
    N/A
    Brake Upgrade?
    Hi All,
    I have noticed that the Roc doesn't seem to stop as fast or hard as my last car. Is there any quick wins to be had in the brake department?
    My old car was a Mazda 323 with an Alcon 4 Piston, 4 Spot callipers that were running on 343*28*55 rotors
    NT
    Huge rotors on this car and I thought it stopped well for a "slider" type of caliper
    I watch with interest
    Quote Originally Posted by preeman View Post
    Hi All,
    Well your Mazda was about 300kg lighter with far superior aftermarket brakes......so of course a stock Scirocco isn't going to stop as well.
    Upgrade the brakes in a similar fashion on the Scirocco and you will get a similar result to your old Mazda.
    Otherwise, pads, fluid and braided brake lines will give you a decent improvement over the stock setup.
    Jan 2012
    N/A
    Since the car uses brakes for stability etc, will it matter if they grip more or are of a different size? Will it throw out some calculations?
    It doesnt seem to effect 10D's Scirocco... the brakes on that are massive...
    10d's Roc
    Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
    Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
