Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Your thoughts on 20mm poke and adaptors
    Jul 2007
    Canberra
    Hey Guys,
    Thinking of giving the rear of the VR a bit more poke so I want to space the diablos out on the rear 20mm. Will be getting the guard lips rolled so will hopefully clear ok? Car is lowered about 40-50mm approx. from stock. I've also seen two different kinds of spacers, the ones that just have holes and you use longer bolts into the existing hub thread and the type that bolt to your hub and then have studs protruding from them to mount your wheel on. Is there any difference between these types i.e. one is stronger than the other etc?
    Simon
    Forever blowing bubbles.
    The slip on spacers you speak of would be too dangerous in a 20mm size, so I would personally go for a bolt on spacer (ie bolt onto the hub) if going 20mm. You can get them made up for around $50 each. As long as they are made well, they should be fine and strong enough to suit the Golf.
    Oct 2006
    I dont think there are any problems provided u get longer bolts equivalent to what spacer size u are using. H+R make up to 25mm spacer plates, and if u think about it all five bolts have to fail before the wheel falls off.
    Jul 2007
    Canberra
    The bolt thru spacers I am talking about do actually sit on the hub (like the H&Rs Peedman mentioned) , not those crappy floating ones, they're dangerous. Same shape as the ones with studs they just bolt through instead.
    Bolt throughs
    http://www.amimotorsports.com/store/..._detail&p=1030
    Stud type
    http://www.amimotorsports.com/store/..._detail&p=1031
    Just wondered if there was any strength differences? I can't really see how there would be as long as they both take the load on the hub.
    Camden, Sydney
    The safer and legal way would be to get a plate made up and bolt it behind the stub axle using longer bolts. It will then just extend the rear beam ad make the trck wider, but cant shatter, or be seen by the cops.
    Jul 2007
    Canberra
    Never thought of that, thanks Matt. Would it be hard to make up you think?
    Nov 2005
    i think do what you feel.... i love it though
    wabit
    Sep 2006
    West Sydney
    I agree. Aydan (gld_gti) just did something similar for his Mk3 as well.
    With adaptors, I would definitely use bolt-ons for a 20mm spacer!
    Jul 2007
    Canberra
    Just did some quick measurements, even with the lip folded I think the max i could go would be 15mm per side. Have to look into it further
    Sep 2006
    West Sydney
    How wide are the wheels, and what size are your tyres?
