Your thoughts on 20mm poke and adaptors
Hey Guys,
Thinking of giving the rear of the VR a bit more poke so I want to space the diablos out on the rear 20mm. Will be getting the guard lips rolled so will hopefully clear ok? Car is lowered about 40-50mm approx. from stock. I've also seen two different kinds of spacers, the ones that just have holes and you use longer bolts into the existing hub thread and the type that bolt to your hub and then have studs protruding from them to mount your wheel on. Is there any difference between these types i.e. one is stronger than the other etc?
Simon
Forever blowing bubbles.
