You should be changing it when you do a new clutch . If the seal does fail your gonna be spilling brake fluid all over a new clutch !
Guys, I'm trying to put my silly car back together. All I've got left to do is spark leads, engine covers, one coolant hose from radiator to engine, a starter motor bolt which isn't impossible but is very annoying, and CLUTCH SLAVE CYLINDER.
My problem is this. When we had my engine in pieces (doing the clutch and timing chains) i pushed the clutch pedal in () and this little gray cylinder looking thing popped right out of the slave cylinder, and I don't know how it is supposed to go back in (I assume before the rod, spring and rubbery thing that are in the slave cylinder now). Can anyone be of any help? Have I actually broken the piece and do I need a new one or is there a way I can squeeze it back in/put it back together and top up the hydraulic fluid?
Cheers guys
Mickey
Yeah i would change it mate as they are common failure items, ive just done a clutch on a VR and changed the Slave, they are around $85 from imparts .
Jmac
Alba European
Thanks guys
Hey wait up a minute...brake fluid?? Where does the brake fluid come from, if we're talking transmission?? lol..
Fed from the brake master cylinder mate, there is a take off hose feeds the clutch master cylinder which in turn feeds the slave on the box.
Jmac
Alba European
And this is why I am waiting for you to do your timing chains before I do them
Lol..this ain't got anything to do with timing anymore Stevie, this is my stupidity getting the better of me..
Seriously.. "why do I have no clutch? *presses clutch*" hahaha..
Oh, and thankyou Jmac I'll be needing to top up brake fluid then..we had to bleed a little off one of the brakes too.
Is the starter in? Does the car start? I`d try that first and see that the chains are working. If not you will have to take it all apart again and can fix the slave cylinder then.
