Results 11 to 20 of 27
Thread: Yes, another "help" thread..
    Sep 2006
    Australia?
    Is the starter in? Does the car start? I`d try that first and see that the chains are working. If not you will have to take it all apart again and can fix the slave cylinder then.
    Agree sutff the clutch throw it in Neutral and see if the car starts and revs nicely! Then play with the clutch.
    Dec 2007
    Ermington, Sydney
    The starter is in minus one bolt so it's a little loose. There's also one pipe that we haven't put back in because it'll get in the way of what we're working on (coolant radiator>engine)
    We haven't put the leads in yet, but I will when we tighten up the starter motor because then it should start.
    Feb 2008
    mOOROOLBARK
    i recently did my starter motor too and that long bolt was the most pain in the arse thing iv ever had to do lol
    there is a bolt on the front connecting the engine mount to the frame i think
    its right near the thread which the long bolt bolts too
    i loosened it and levered it towards me
    sorry if that didnt make sence im not very good at explaining things
    Dec 2007
    Ermington, Sydney
    I'm not 100% sure if I understand, but I think I know what you're talking about lol. Thanks man.
    Dec 2007
    Ermington, Sydney
    ....Okay so I ordered a new slave cylinder. Is it as easy as undoing the fluid lines from the old cylinder and bolting on the new one?
    Quote Originally Posted by Mrk_Mickey View Post
    Yeah, then you have to bleed it. Make sure the brake reservoir is topped off and open the bleed nipple. If you just wait the fluid runs through under gravity. Wait for the bubbles to stop and nip it up.
    Aug 2007
    Good point Matt , yeah dont stuff around with the cylinder , i agree totally , c what you got engine wise first mate.
    Jmac
    Alba European
    Dec 2007
    Ermington, Sydney
    Thanks guys. We just need a long 16mm socket to put the starter bolt in, then we'll plug in the leads and start her up. Timing is all fine, since we checked/tested it etc, hoping it is ok on startup now Thanks Gavin for the tip.
    Dec 2007
    Ermington, Sydney
    Alriiiiight! Everything is ready to go Silly me forgot to buy brake fluid so I haven't been able to bleed the slave cyl yet, but everything else is ready to go (minus coolant) so she'll be starting up tomorrow I'll let you all know how I go. Thanks for all the help!
    Dec 2007
    Ermington, Sydney
    One last question guys
    I'm just wondering, to bleed the slave cylinder, does it matter if I have already bolted it into the gearbox? That was a PITA..I really hope I don't have to undo it again lol.
