looks like o2 sensor to me, whats your o2 voltage look like?
My exhaust has smelt a little rich recently. especially on startup. So today being my day off i decided to have a bit of a poke about and give the car scan with the ol vag-com.
ive thrown the below codes. Just wondering b4 i start ripping into things if anyone has experience with similar codes b4? Im thinking of swapping out the O2 sensor with a spare one i have kicking about. The codes come back within a few seconds if you clear them.
Monday,10,September,2007,12:33:09:42388
VAG-COM Version Release 704.1
Data version 20070723
Chassis Type 1H - VW G/J/V Mk3
Scan 01 02 03 08 12 15 25 41 56
Address 01: Engine Labels: 021-906-258.LBL
Part No: 021 906 258 CH
Component: MOTOR 2,8L 6-Zyl.
3 Faults Found:
00561 - Mixture Adaptation
15-10 - Adaptation Limit (Add) Not Reached - Intermittent
00537 - Lambda (Oxygen Sensor) Regulation
08-10 - Control Limit Surpassed - Intermittent
14-00 - Adaptation Limit (Add) Exceeded
Readiness: N/A
Address 03: ABS Brakes Labels: 3A0-907-379.LBL
Part No: 3A0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 00000
No fault code found.
Address 15: Airbags Labels: 6N0-909-60x-VW2.LBL
Part No: 6N0 909 603 E
Component: AIRBAG VW2 V00
Coding: 00069
Shop #: WSC 00021
Address 25: Immobilizer Labels: 1H0-953-257.LBL
Part No: 1H0 953 257 B
Component: IMMO VWZ3Z0S0449102 V00
Coding: 09600
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
havent got that far yet im busy sitting on my arse watching cooking shows on tv!
Mate check for split hoses/vac lines etc that can throw them codes. Watch the O2 sensor in measured value blocks with Vag com mate and see them fluctuate.
Alba European
if i had a vacuum problem wouldnt my idle be all over the place?
Check those codes on Ross Techs site and also look for the explanation of fuel trim. I can't remember which way it goes but one form of the problem occurs at idle due to an air leak which the ECU cannot compensate for.
Found it, http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
Ok then mixture adaption code 00561 is related to unmetered air. What is a vac leak??????? Hmmmm. G70 airmass meter also could be faulty and of course once again the lambda probe. Unmetered air also upsets the lambda probes. A sticky activated charcoal valve or too high fuel pressure also throws this code. 000537 also relates to unmetered air, or fuel pressure too low so it cant be that coz 00561 means it could be high. Back to unmetered air. Dont know how many times ive seen lambda probes fitted and there is nothing wrong with them, just because a fault relates to lambda it doesnt mean its the probe. The probe is reading what its getting guys, corrcet me if im wrong. When i was with Porsche the boxters were bad for throwing these codes and it ended up being a split crankcase breather hose (unmetered air) very rarely fitted probes unless they were old and tired.
Alba European
hmm interesting article. looks like there is a bit of research for me to do in regards to trouble shooting this one.
