auto's are expensive to fix and will likely break again sooner rather than later. headliner is a sinch (you should take a look at the DIY thread and re-do the pillars at the same time).
With all the body work it needs, tell them you will buy it off them for $2000 and then save it for later. It can be a project car so that you can get your green p's and convert it to a manual.![]()
