Results 1 to 4 of 4
Thread: wiring problem? or...
    Apr 2006
    Carlton, VIC (HK now)
    sigh... summer has come up, and its time for problems to appear as well
    yesterday i was going left on my indicator light and it appears to be flashing much faster, thought a bulb gone, then it appears to be working normal again, was on the front it doesn't work, today it came up with the rear light
    also there are sseeeezzzzz seeeezzzzz... sound coming out from the steering when i turn it at around every 90-180 degree, from straight, found out the copper behind the steering at the bottom is hanging out, is it supose to be hanging out, or back it... or lubricate it?? Thanks bros
    Carlson
    Sounds like you might be talking about the contacts for the horn push. They should be pretty clean with a small amount of grease to stop oxidation.
    The plastic work on the column is famous for rubbing and making annoying noises.
    brackie Guest
    Horn ring
    Yeah... There should be some grease on the horn ring. Many of them fail because they dry up and wear out.
    Indicator problem sounds like a poor earth or contact with the centre of the globe. Clean things up and it should go away. (If the flasher unit was on its way out it would affect both sides of the car )
    Apr 2006
    yea, thanks guys, just sprayed bit of CRC till i got grease n the light globe contact.
    Carlson
Similar Threads
  1. 95 Ibiza Window Problem
    By VdubDownthePub in forum The Lounge SEAT
    Last Post: 01-03-2007, 03:17 PM
  2. VR6 thermo fan problem
    By Oli in forum Mk3 Golf & Vento
    Last Post: 15-02-2007, 06:28 PM
  3. Replies: 9
    Last Post: 11-02-2007, 05:58 PM
  4. new deck install problem...help
    By deemoE36 in forum Mk3 Golf & Vento
    Last Post: 13-01-2007, 11:01 PM
  5. Wiring Diagram
    By el_foolio in forum Mk1 Golf
    Last Post: 11-11-2005, 09:56 AM
