Page 9 of 19 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 189
Thread: Winter project.
  1. #81
    Sep 2006
    West Sydney
    How much was the bra Joe? I recently bought one as well and I paid a little over $100AUD. I expected leather but it wasn't...
  2. #82
    Q
    Quote Originally Posted by rayray086 View Post
    Yeah was about that too, was a bit disappointed it wasn't leather, but still has a nice feel and I can't complain about the fit, like a glove. Meant to be German made (no doubt with a stop over in China...but meh) so feels quality enough, and I wanted one with the two triangles. On a Vento the ones without supports would just look like a beach towel closed in the bonnet.
    Also note, bonnet isn't shut because I still have to have a play with the catch before I shut it, bumper is currently unbolted and grill is loose, so the lines aren't spot on at the mo' but will be soon.
  3. #83
    Jan 2011
    Rooty Hill, Sydney
    i really think you should stop playing with us
    put up something more recent !!
    paint & plastics looks tops to going by that 1.
    Garage:
    VR6
    XR6
    R36
  4. #84
    bonnet bra looks the goods
    got any pulled back shots of the car now?
  5. #85
    Dec 2010
    Gold Coast, Queensland
    PM me with what you want for the wheels and tyres, might be interested. I'm on the gold coast.
  6. #86
    Q
    Quote Originally Posted by dark View Post
    PM'ed they need some TLC, but aren't goners.
    Also Koni Yellows with Eibach springs (for a Mk3 Golf NOT Vento...Vento-able with different rated back springs) will be available too (they're used, and need new bump stops... but are damper adjustable and are a nice ride, can PM photos for ideas of heights)
  7. #87
    Q
    Saturday arvo... obviously wound high.
  8. #88
    Quote Originally Posted by VW Imposter View Post
    lower it!
  9. #89
    Q
    Ok need an opinion. We took my old Koni Yellows out of the Vento, they had matching run of the mill nut and bolt at the base, put in the coilovers, same deal normal nut and bot. Took some Monroe or whatever annonobrand suspension out of the colourconcept and the top nut (at the base of the stut) has a toe/camber ...erm...thing, its like a normal bolt with an oval section toward the head of the bolt. What are everyones thoughts on losing this? I.e. going from this bespoke bolt to just two standard bolts through the base of the strut?
    Colourconcept killed it in the bends on its new Konis.
  10. #90
    Q
    Ok, had a problem with my A8 reps, they fit fine over the more narrow earlier brakes, but not the later.
    They do fit, but my solution was to dremmel just a chamfer on the edge of the brake pad carrier, this stopped it rubbing against the inside of the wheels, not the spokes but the fat part where it mounts to the hub.
    So, time came for some new brakes again, and I was about to get my GIY grind on.
    and I thought I'd take a different approach.
    Was planning on refurbing them, but they are so mint that the damage is less curbing and more slight imperfections.
    ..and don't worry that's not right off the jack, the car will be lower... I've just never been a fan of the block under rim thing, and couldn't find a jack to put under the suspension. Really just a test fit for clearance.
