I have installed Eagle Eye Smoke LED tail lights in my mk3 Golf. They do not work exactle how I would expect them to. The grey and white wire in the luggage compartment had nowhere to plug into on the left tail light set. The wires on the left tail light set are the same as the wires on the right tail light set, with nowhere for the grey and white wire to go. The stock left tail light set had a plug for the extra wire to go.
The (red) ring of LEDs for the night lights and the top row of (red) brake LEDs work, and work when they are suppose to. The indicators function normally and the reverse lights work. The bottom row of (red) LEDs do not come on with the brakes; instead, only the bottom row of LEDs on the left tail light come on when I turn on the fog lights. I want the reverse lights to come on when I turn on the fog lights, like they do with the stock tail light sets installed. I want the bottom rows of (red) LEDs on both the left and right tail light sets to come on when I brake.
Has anyone else had this problem and if so how did you fix it? Any assistance with this problem would be much appreciated!
