if you've got the switch out, then look on the sides of it, if you use a small screw driver you should be able to GENTLY open the gaps at the side to let the inner clips separate from the surrounding plastic and the inside of the switch should slide out the back of the part of the switch that actually has the buttons on it.
that probably didnt make any sense...try it anyway.
-steve
sorry if that didnt help at all
but once you've got it unplugged you should be able to separate it once more so you can see the globes
