Results 1 to 7 of 7
Thread: Window Problems...
    Alfred Cove, WA
    Window Problems...
    Alrighty,
    So the window regs on my back windows of my 2.0L golf both went at the same time.... One window jammed down, the other jammed up. I've solved the lowered window with my special woodworking skills and its fixed for the time being......
    BUT...
    The front passenger window stops working sometimes and can generally be fixed by turning off the car, cursing, starting the car again and she works fine then. Is this typical window regulator failure on the front or a wider electrical problem on the window circuits? Thoughts?
    Quote Originally Posted by Kai View Post
    And then dont forget the most important mod for gays.
    Blow off valve - 300
    Sep 2006
    I had this when I had my VR6
    I replaced the motor and reg with a fairly new one
    I think it is something to do with the wiring in the car
    Be interesting to see if anyone else knows
    Dec 2007
    Ermington, Sydney
    Sounds like it could be faulty wiring, yes. Although that'd be a hard thing to check unless you were game with a multimeter and knew what to look for, which I can't comment on hehe.
    Apr 2006
    Hobart,Tas
    A hell of a lot of the window probs on mk 3's these days are broken wires inside the rubber tubes going to the doors from the body I have found over the last few years...
    Dec 2007
    Ermington, Sydney
    True!
    My rear right window seldom works, and that's directly related to the wires in the door rubber. If it doesn't work, I twist the door rubber to the tighten position, close the door again and it works.
    Jan 2010
    Yes, can be typical of the Motors...... i think its something to do with the alarm/key.... i have had a few weird window moments while opening and locking the car with the key where the front passenger window would go up and down on its own......
    I did find a forum a while back that reckons it might have been the ignition switch, which typically wears out.....
    Sep 2006
    Quote Originally Posted by mattross View Post
    Maybe that is why I could get it to work when i turn the ignition on and off multiple times
