put your key in the door.
turn it to unlock and hold it. see if any of the windows work.
this will rule out window regs and may point to a problem window
im having similar crazy issues atm
So windows in my vr6 are all working fine i prk the car come back 1 hour later and none of the windows work at all not the front or back!
Not a fuse problem cause i checked and i dont think all 4 window regulators would go bad at the same time. Anyone come across this problem.
Ohh and everythin else works fine all the lights swithes side mirrors radio etc...
Yeh i tried that and no window opened.....
wow thats really weird, i have the same issue all of a sudden, thinking it was a reg, i took a reg out of the door and its working intermittenly out of the door = even stranger....
Do the window switches light up when you turn the lights on
Yeh all the switches light up i think a wire made contact from melting in the hot weather im gonna have to check that all out
keen to see what you come up with.
I had similar.
no windows, no mirrors. fuse looks fine (even swapped it to be sure), switches have lights
windows work via key.
replaced both rear door looms as I know they were pretty had it.
still no chop
currently got the dash apart (again... 10th time...?!) chasing other things plugged into that same bunch of wiring/relay
