I think this needs to be cleared up cause there is so much wrong info here .
The 12V has 2 different oil filter housings but uses the same gasket for both of them . The only difference is the actual oil filter .
The part number for this gasket is 021115446A
The 24V uses a different gasket . This is actually 2 gasket pieces both are the same unlike the 1 piece 12V unit . (dont have part number will get it and edit later)
The seals loon is talking about are the oil cooler seals . The outer one is 038117070 and the inner one is 038117070A . They are a more common leak and Euro Revolution keeps a few of these in stock .
Hope that clears it up !
Bug_racer supports the rebellion of the euro revolution
