Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Wheels sizes for VR6 - its driving me nuts!
    Aug 2008
    Rowville, VIC
    tried some wheels yesterday. exactly what i wanted for the price i was willing to pay.
    mortified that they didnt fit.
    specs were 17x7 et43.
    punched the specs into this site http://www.rims-n-tires.com/rt_specs.jsp and it looked like there were ok to fit.
    tried them on, only to find the calipers fouled on them.
    now ive tried other sizes on this calculator on wheels i know fit according to this site (17x7.5 et35) and from the site, they look ok.
    is there a definitive guide for 17's on a vr6?
    must it be 17x7.5 et 35? if for a 17x7 wheel should the offset be?
    would it be same to assume that the wheels i tried had the incorrect offset put in the ad? i didnt check physically on the wheel cuz i was cut.
    and id rather not have spacers. but if i needed one for these wheels theyd need to be at least 15mm (yes the wheels were from a suby)
    cheers
    Jan 2008
    Melbun
    the problem you're having is that the calipers are hitting the spokes, not that the offset/size is wrong.
    2x Caddy, 1x Ducato
    Boronia VIC
    There's no measurement published that will tell you if a wheel is going to clear the caliper.
    Even a wheel with the exact same diameter, offset, width, PCD and centre bore as your original wheels might still foul the brakes.
    It still comes down to trial fitting I'm afraid, unless you can find someone who's already got the same wheel fitted to your model car.
    So once you've figured out the dimensions you need, you might have to try a couple of styles and brands before you get one that fits.
    If all else fails there is some scope to modify wheels and brakes but it's a fair commitment to go there.
    Hope this helps
    Pete
    Aug 2008
    Rowville, VIC
    oh ok, i like those answers.
    i thought i was going insane. i thought that years ago, i had grasped the concept of wheels but then i bought a euro car and things werent as clear!
    The same concept applies no matter what car it is pretty much!
    Just run some decent 15mm H&R spacers to clear the wheel from the caliper if need be (plus it looks better having less guard to wheel clearence!)
    Sep 2006
    West Sydney
    A popular misconception that people think offsets tell them about brake caliper clearance.
    Unfortunately, spacers are the only option in this case.
    Oct 2006
    Quote Originally Posted by Lorenz View Post
    15mm is huge, theres no way that the caliper is fouling by that much. A 5mm should suffice fine, the vr6 caliper isnt that huge anyway.
    Jul 2007
    Canberra
    You may be able to get away with sub 10mm spacers, I run 7mm on my fronts and have used those on 2 different sets of wheels with no dramas. Just ensure that you get hub-centric spacers and not those dodgy floating ones, they really aren't safe.
    Forever blowing bubbles.
    Aug 2008
    Rowville, VIC
    Quote Originally Posted by peedman View Post
    it was definetly around 15mm. we used veniers(sp?) and a coupla floating spacers to get the measurement.
    Jul 2007
    Canberra
    They must be massively deep spokes! I tried about 4 different styles before deciding on the current ones and the 7mm spacers allowed all of them clear. Any piccies or links of the wheels you're looking at?
