Results 1 to 10 of 16
Thread: Wheels etc
    Jun 2007
    Dirty West!
    Wheels etc
    Hi all,
    I have a few queries that i would appreciate opinions on re my mk3:
    1. I have a set of wheels, 17x7.5 et 25. will this be too much poke? If anyones got any pics of a mk3 with such a set up, it would be much appreciated.
    2. My gear shift lever is very loose. Say if i were to put it in neutral, the gear stick is very loose, it moves very easily as if something is loose.
    any thoughts?
    Aug 2006
    Melbourne VIC
    7.5 et25 should be ok. Just depends of tyres, how low you are and if guards are rolled.
    Id suggest to check out your gear shifter bushes.
    Jun 2007
    Dirty West!
    thanks mate.
    right now stock as a rock, but coils soon. what size for tyres? right they've got 205 40 17
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by Water Boy View Post
    this is all 100% spot on.
    205/40 will be fine.
    i like volkswagens
    Sep 2006
    Parkinson / Brisbane
    this is 17x8 +25 for reference, so your 7.5's will sit 6mm in from there.... the front has nearly -3.5deg camber though and running 215/40 rear and 205/40 front...
    Jun 2011
    Heres my car with 16x7.5 +25 195/40s
    In these photos the coils are as far down as possible with helpers and no guard work at all.
    It really isn't very aggressive so you'll have no troubles.
    I'd recommend 195s for 7.5" wide wheels.
    Honda Civic Owner
    Jun 2007
    Dirty West!
    Thanks Fellas. Unless i've got the offset wrong, when test fitted, they stuck out far more than the pics posted. How can i measure the offset?
    I'll post a pic up on the weekend and will appreciate opinions. Do the dynamics change when you lower it?
    Nov 2010
    sunshine,vic
    it should say the specs on the inside of the wheels , something like 17x7.5 ET 25 which is the offset ? well most wheels do
    94' Golf Mk3 Vr6
    depends on your height too
    Jun 2007
    Dirty West!
    **** me....its et 15. too aggresive??? tried looking for pics. serious guard rolling is needed.
