Results 1 to 10 of 15
Thread: Question about adapters
    Mar 2011
    Inner West, NSW
    Heya guys,
    so I'm looking at getting 5x100>5x120 adapters from Adaptec but am a bit stumped on which type of adapter to purchase.
    Now I know the benefits of getting hub-centric adapters but seeing as though the wheels I'll be putting onto these adapters have a large CB (72.5) would it be benefitial to also order the hub+wheel centric adapter?
    I don't want to purchase the two-piece adapters and I know I'll be ordering a 20mm thick adapter.
    thoughts?
    Jun 2011
    I'd you get yourself the smallest hub you can get. 57.1mm in this case. You can just use a hub ring on the wheel side, then you can use all wheels with a 120pcd and don't need to worry about machining cb's.
    Mar 2011
    Inner West, NSW
    That actually sounds like a smart idea Hayden! Wont be limiting myself to just 72.5CB wheels. Never thought of it that way.
    cheers
    Wheel and hub centric for sure.
    You only need single piece adapters for 5 to 5 stud conversions.
    What Hayden said is a good idea, as long as 57.1-72.5 rings (and other sizes you may want to run) are readily available
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2012
    Melbourne, VIC
    I also have a question but its completely different,
    i want to put a set of porsche lobster claws on my mk4 r32, but I'm afraid that the adapters will **** with my performance and whatnot, i don't know anything about adapters, but I'm thinking that on the fronts, if i take a hard corner wouldn't that put a lot of stress on the longer bolts?
    Mitch
    Mk1 Gti 81 2Dr
    Mk2 Gti 88 2Dr
    Mk4 R32 04
    Sep 2006
    West Sydney
    Quote Originally Posted by mitch750 View Post
    Mitch
    As long as the adapters are well made and are hub and wheel centric, your only problem is the increase in unsprung weight.
    Jun 2011
    They are fine. I've done some severely hard driving on ****ty roads at stupid speeds never had an issue. Adaptec/H&R though are tough as.
    Use quality adapters correctly and its fine.
    No difference to using the wrong bolts or not tightening correctly on normal wheels.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2012
    SE Melbourne
    In 20mm there's enough thickness to be 57.1-57.1 hub and wheel centric that's deep enough for the longer rears, go for it.
    SILVER '98 MKIII GOLF GL // BORBET TYPE A's
    YELLOW '76 B1 PASSAT LS WAGON
    WHITE '07 MKV JETTA 2.0 TFSI
    FLICKR
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by LankyVW View Post
    yeah, im going with 20mm all round so I can get some crazy dish on the rears and have it somewhat flush at the front. Still have to measure up what size barrels and lips I want so yeah
