Results 1 to 7 of 7
Thread: Wheel/rims clip
    Mar 2014
    Bundoora, Victoria
    Wheel/rims clip
    ok...so it was wet and slid a bit out of a turn. Managed to hit the separator bit of cement and give the car a good jolt.
    I've had a look around everything and the only visible damage I could find was that the rim was badly scratched, ok that's not too bad, but then I noticed the clip. It's a metal clip that has 10G engraved on it and it was a bit out. I compared it to the other wheel. That one has the clip completely touching the rim.
    I'm not sure what this clip does and how essential it is but it's out of place and I'm a bit worried.
    Any advice?
    Past - '95 VW Golf MK3 VR6
    Jun 2009
    Can you get some photos so we know what you are talking about?
    It's a wheel weight used for balancing.
    10g isn't much, and being you have tapped a gutter is be going to get a balance / alignment anyway.
    Get them to put stick on ones if you have nice wheels, I hate the damage those external ones can do
    Mar 2014
    Bundoora, Victoria
    The left side which is unaffected.
    Wheel/rims clip-img_4209-jpg
    The right side which I hit.
    Wheel/rims clip-img_4208-jpg
    Jun 2009
    As Dylan pointed out, these are the wheel weights, used to balance the wheels.
    Mar 2014
    Bundoora, Victoria
    So, unless I can feel a change in the steering I shouldn't be worried?
    Jun 2009
    Quote Originally Posted by stefcio007 View Post
    Well as Dylan said, you should probably get an alignment done if you hit the kerbing hard enough to dislodge the balancing weight so they should refit it for you when it is aligned and balanced.
