You wont get much stretch with a 7" wide wheels unless you go to something like a 185/35/17
Grab a wheel offset calculator (google) and plug in different specs (ET of wheel - size of spacer will give final ET).
Use a ruler and see what size spacers will give the look you want.
It's a guide only, but will give you an idea of the difference between where they will sit with a 5mm spacer to clear the shocks and a 25mm spacer with potential poke.
Hey guys . . i used 8mm spacers for the front and the back .. they fit beautifuly .. it's just that my steering wheel shakes a lot when im doing over 60 km/h .. is it just a wheel alignment/balance issue ? or is it something else ?
VW BORA 2003 V6 4Motion
Volkswagen Golf MK3 1997 CL 1.8L
Rammstien + Autobahn + Volkswagen = Leben !
Wheel balance issue or the bolts could be working loose... just re-torque the bolts and take it to tyre place and get the wheels balanced. It's a good idea to have a wheel alignment done at the same time too.
I would have said to change the tyres to 205/40 as that might help with the suspension clearance but you've got the spacers now so no worries.
will get some rings before i do my balance and alignment . so i shouldnt really freak out about it ! thanks guys !
