VR6 was 5x100, offset around 30-40 as a ballpark, someone with more specific MkIII knowldge should be able to provide better detail.
Right,
no idea wtf is going on in the world of VW's / Front Wheel Drives in general.
16x8 Wheels, what kind of offsets will sit nicely (just legal) on a MK3 Golf?
Will there be clearance issues with wheels that wide on a front wheel drive?
And ALL MK3 Golfs are a 4x100 Stud pattern...
It pays to check these things lol.
Cheers,
Joe
vr6 standard weels are 15x6.5 et43 5x100. idk about the other models though
5 x 100? Is that not also the crazy subaru size, sounds familiar to me, or is the difference in the et43 that you mentioned, this is the distance between the inside edge of the rim and centre hub yes?
96 VW VR6 Golf (Daily driver)
65 VW Beetle (Under restoration)
yeah some subarus are also 5x100. vr6 has a centrebore of 57.1 i should also add.
The subaru with the same stud pattern have a smaller centrebore and either a really high or low offset (i cant rememebr) which makes not many of there wheels friendly to fit...
I cant remember exactly, i havent been on it in a while but, tirerack.com, you used to able to put your car in, and what size wheel. Then it would tell you what wheels could fit, or if you would need to do modifacations, spacers, etc.
