Results 1 to 10 of 25
Thread: Wheel Fitment - VW Noob Question - MK3 Golf
    Apr 2011
    Brisbane Australia
    Quote Originally Posted by LWR View Post
    A 7.5x16 ET35 was OK on them, so maybe an 8x16 ET30 or so might be too.
    8x16 ET30 wouldn't be exactly legal.I'd run with a 7.5x16ET35.
    2010 Golf R 5 dr , Black , DSG , Leather and 8.5x19 ET50 AZEV Type R
    May 2011
    Nova Sotia, Canada eh!
    I cant remember exactly, i havent been on it in a while but, tirerack.com, you used to able to put your car in, and what size wheel. Then it would tell you what wheels could fit, or if you would need to do modifacations, spacers, etc.
    Jun 2007
    Eastern Suburbs Melbourne
    what makes you say that?
    8" et30 will only extend an extra 40mm (from stock). Still some room before that's close to the arch. (i'd say about 20mm before it's even close.) Also, it's only 10mm further out from the 7.5 et35. Tyre size will also have effect.
    i like volkswagens
    Apr 2011
    Brisbane Australia
    Yes but you will be overtracking it.Last time I checked,no track change was permitted on FWD cars.
    Jun 2007
    Not 100% sure, you mean the inscreased track is illegal? According to the RTA?
    Source/link please?
    This has never been and issue for... approximately 100% of people on this forum that have fitted wider wheels. (poke and stretch however, is another story)
    i like volkswagens
    Apr 2011
    Brisbane Australia
    Source please?
    It's probably best to check with the Victorian traffic authority.It used to be up here (and it may still be) that you were permitted to go an inch wider than than the widest wheel offered by the manufacturer and 26mm wider in track ie 13mm less offset on RWD cars.On FWD cars,you could go the inch wider on the wheel as long as there was zero track/offset change.
    It may have been relaxed but I'll try and find out more for you.I just did some Googling but information seems hard to get.
    Jun 2007
    Yea, it sounds vaugely familiar.
    Technically, yes, it may not be illegal. 99 times out of ten you wont get pinged for it. Hell, how would a policeman even know?
    i like volkswagens
    Apr 2011
    Brisbane Australia
    True.Some insurance companies may dig their toes in if there's an accident though.
    Every state has more than likely got different legislation.
    What tyre size were you planning to use?
    i couldnt imagine it to be right... cars come with different wheel widths and offsets from factory.
    back on topic, have a crack at the offset calculator in the wheel and suspension section (i have it saved in my favourites...). heights and things like that can also play a part.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
