Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Wheel Fitment - VW Noob Question - MK3 Golf
    May 2011
    Brisbane QLD
    Question Wheel Fitment - VW Noob Question - MK3 Golf
    Right,
    no idea wtf is going on in the world of VW's / Front Wheel Drives in general.
    16x8 Wheels, what kind of offsets will sit nicely (just legal) on a MK3 Golf?
    Will there be clearance issues with wheels that wide on a front wheel drive?
    And ALL MK3 Golfs are a 4x100 Stud pattern...
    It pays to check these things lol.
    Cheers,
    Joe
    Jan 2009
    blankedy
    VR6 was 5x100, offset around 30-40 as a ballpark, someone with more specific MkIII knowldge should be able to provide better detail.
    Sep 2009
    vr6 standard weels are 15x6.5 et43 5x100. idk about the other models though
    Apr 2011
    5 x 100? Is that not also the crazy subaru size, sounds familiar to me, or is the difference in the et43 that you mentioned, this is the distance between the inside edge of the rim and centre hub yes?
    96 VW VR6 Golf (Daily driver)
    65 VW Beetle (Under restoration)
    Sep 2009
    yeah some subarus are also 5x100. vr6 has a centrebore of 57.1 i should also add.
    The subaru with the same stud pattern have a smaller centrebore and either a really high or low offset (i cant rememebr) which makes not many of there wheels friendly to fit...
    Apr 2011
    Brisbane Australia
    Quote Originally Posted by sortofbigbj View Post
    Toyotas were 5x100 as well with a 54mm centre bore
    2010 Golf R 5 dr , Black , DSG , Leather and 8.5x19 ET50 AZEV Type R
    Apr 2011
    Brisbane Australia
    Quote Originally Posted by nastylilweed View Post
    Right,
    Cheers,
    Joe
    A 7.5x16 ET35 was OK on them, so maybe an 8x16 ET30 or so might be too.
    Apr 2011
    Brisbane Australia
    Quote Originally Posted by LWR View Post
    8x16 ET30 wouldn't be exactly legal.I'd run with a 7.5x16ET35.
    May 2011
    Nova Sotia, Canada eh!
    I cant remember exactly, i havent been on it in a while but, tirerack.com, you used to able to put your car in, and what size wheel. Then it would tell you what wheels could fit, or if you would need to do modifacations, spacers, etc.
    Jun 2007
    Eastern Suburbs Melbourne
    what makes you say that?
    8" et30 will only extend an extra 40mm (from stock). Still some room before that's close to the arch. (i'd say about 20mm before it's even close.) Also, it's only 10mm further out from the 7.5 et35. Tyre size will also have effect.
    i like volkswagens
