Results 11 to 20 of 25
Thread: Wheel Fitment - VW Noob Question - MK3 Golf
    Apr 2011
    Brisbane Australia
    what makes you say that?
    8" et30 will only extend an extra 40mm (from stock). Still some room before that's close to the arch. (i'd say about 20mm before it's even close.) Also, it's only 10mm further out from the 7.5 et35. Tyre size will also have effect.
    Yes but you will be overtracking it.Last time I checked,no track change was permitted on FWD cars.
    2010 Golf R 5 dr , Black , DSG , Leather and 8.5x19 ET50 AZEV Type R
    Jun 2007
    Eastern Suburbs Melbourne
    Not 100% sure, you mean the inscreased track is illegal? According to the RTA?
    Source/link please?
    This has never been and issue for... approximately 100% of people on this forum that have fitted wider wheels. (poke and stretch however, is another story)
    i like volkswagens
    Quote Originally Posted by LWR View Post
    i couldnt imagine it to be right... cars come with different wheel widths and offsets from factory.
    back on topic, have a crack at the offset calculator in the wheel and suspension section (i have it saved in my favourites...). heights and things like that can also play a part.
    Apr 2011
    Brisbane Australia
    Source please?
    It's probably best to check with the Victorian traffic authority.It used to be up here (and it may still be) that you were permitted to go an inch wider than than the widest wheel offered by the manufacturer and 26mm wider in track ie 13mm less offset on RWD cars.On FWD cars,you could go the inch wider on the wheel as long as there was zero track/offset change.
    It may have been relaxed but I'll try and find out more for you.I just did some Googling but information seems hard to get.
    Jun 2007
    Yea, it sounds vaugely familiar.
    Technically, yes, it may not be illegal. 99 times out of ten you wont get pinged for it. Hell, how would a policeman even know?
    i like volkswagens
    Apr 2011
    Brisbane Australia
    True.Some insurance companies may dig their toes in if there's an accident though.
    Every state has more than likely got different legislation.
    What tyre size were you planning to use?
    May 2011
    Brisbane QLD
    Basically i am totally not in my comfort zone with FWD's.
    I wanna basically sit it at 100mm with decent fitment for a daily.
    What do i need to do this? lol, probably the easiest way ask it...
    Jun 2007
    coilovers, 16x8 all round, roughly ET 25 with a 205/40 as the safer option, but a 195/45 would be better for clearance, given that 100mm is pretty low.
    will it be 'legal'? Not really. but if you're going to run at '100mm', you're probably down for pushing the boundaries...
    i like volkswagens
    May 2011
    Brisbane QLD
    Jan 2009
    blankedy
    8" wide without poke and rubbing may be fiddly or restrictive to what rims will fit. I'd get it dropped and work from there.
    If you are running a slight stretch (still within spec), I don't think it improves handling, just looks. Nothing wrong with that.
    You could always measure it, but as the camber geometry will change when it's dropped, best to drop it first.
