Results 1 to 7 of 7
Thread: Whats this thing and why did it explode?
    Dec 2010
    Gold Coast, Queensland
    Hey Guys,
    Looks like i found the cause of my issues - but not knowing alot about vr6 engines.....what the hell is it? And why does it appear to have exploded?
    It also has this sponge thing inside it _ I assume it was some sort of breather filter??
    Heres what was left of it that I found under my car!!
    Not sure what happened here but think it might be part of the issue!!
    Dec 2006
    Kilsyth, VIC
    That's the idle stabiliser and they all blow up
    AFAIK I know it can be safely deleted, although I have never had one so can't help with the procedure.
    Sep 2009
    Thats the ISV muffler (not the actual ISV itself), relatively common that they blow up supposedly haha. Fairly sure you can just bypass it by connecting the isv straight to the intake, deleting that bit. I have done it but havent run the car since (I did it merely to clean up the engine bay a little, but havent started the car as im still waiting on a new sump and oil pump...)
    You can also delete the isv all togehtor and block it off at the intake tube and the intake manifold, or just unplug it and that will also stop it. Only thing is the car might stall if you try running the ac and such at idle as it wont automatically bump it up a little. I ran mine unplugged for a week or so too see if I could run it without the thing, and it was fine, however i never tried the AC.
    If you want to replace it you can get a new one off gap for a bit of cash, or alternatively if I get my c ar up and running again and it runs fine I'd send you mine for a little.
    Sep 2009
    and yeah that would most likely explain why your car hasnt been running, sucking in a tonne of unmetered air...
    Dec 2010
    Thanks guys - I knew someone would recognize it! I dont have working Ac so maybe I'll just bypass it.
    Jan 2011
    Rooty Hill, Sydney
    looks like your problem is solved. About that stubborn bolt, if you still havent got it off, you could drill a hole through the side of the bolt head, then stick the longest thickest piece of metal you can get (this magnifies you turning power) in it, then use either your hands or a hammer to turn it.
    dont drill to big of a hole cause then you might break the bolt head.
    OR
    You can fill the sides till you have the edges back again, then take it to a garage that has a nut gun.
    kay
    Garage:
    VR6
    XR6
    R36
    Dec 2010
    bypassed my isv muffler today and disconnected the battery to reset the ICU and what do you know - the sucker runs! Now to deal with my stubborn suspension bolt, cactus cooling system and whatever else breaks and I'm in business!
