there dont seem to be any "kits" but using that manifold which is actually made by SPA turbo in brazil u can piece together something. Only problem is there are no real drop in chips to suit our ECUs. So stand alone is probly the only real option at this stage. Check out some of the UK builds on www.vr6oc.com
One guy even used his stock ECU with a rising rate FPR. Although his A/F ratios werent perfect. They were reasonably safe.
