Results 11 to 20 of 33
Thread: what turbo manifold for a RHD vr6 ???
    Sep 2006
    Australia?
    I've heard that there alot of problems but with a supercharger you can just bolt it straight on and you won't have to change compression ratios and that.
    Point Cook, Vic
    its the same with a turbo or supercharger. if u run a lot of boost you need to reduce the compression. if u keep it under 8psi u can run reasonably safely with stock compression.
    i wouldnt say one is more reliable than the other. you can have issues with both.
    FOLLOW US ON FACEBOOK
    Jan 2007
    with a super charger is't it a bit more stable?
    With a turbo woun't it be the boost kickes in
    and see you later from end?? I guess it
    depends on how much boost.
    Dec 2006
    hurstville,sydney 2220
    how much boost do u think ur gonna run out of a bolt on super charger anyway not as much as a turbo and the only reason y turbo are worse coz people push them abit to far, as for super chargers u can run safe low psi and still get alot of power out of them and cheaper!
    Point Cook, Vic
    supercharger setups usually cost more than a turbo from what i have seen. make less power and higher in the rev range. Nothing against them. But i think a turbo is a better option.
    Dec 2006
    ur probably right if u wanna get the same power out of a super charger then ur getting out of a turbo it will cost more but for what ur after 220 at the wheels id suggest u find urself a t28 ballbearing turbo, boost controller, gtr front mount, waste gate, BOV, just remap the computer and heavy duty injectors ( ur obviously gonna need custom manifold dum pipe and exhaust) but ull easily get 220 at the treads running 1 bar and ul spend around 2g'z on the parts and im not sure how much on istallments and the manifold and all the way through exhaust but doubt it will b more then 5-6 g'z and ull make over 220 ( my dad spent around 5 and his making 200 at the wheels on his soarer) hope that helped
    Sep 2006
    Australia?
    Quote Originally Posted by Tim
    You can set them to run when ever you want can't you?
    Dec 2006
    Quote Originally Posted by Mk3vr6
    with super chargers because there run of the belt (unlike turbo's hit on boost hard at about 3 and stay on till red line) the superchargers get higher boost the faster the belt spins and depending on the pulley ratio
    Oct 2006
    That would only be true assuming you have a high displacement supercharger which requires a comparatively greater effort to reach max boost.
    It all depends on what application/size you look for but if your not gonna run more than 8psi, theres no reason why a smallish supercharger cannot make that same power for the same cost possibly even cheaper.
    Point Cook, Vic
    true. its all in the pullies and strings really
