Brakes and Bolts
Hi Guys,
I've done a bit of digging, but does anyone know where I can find a DIY for front brakes on the VR6? Is it just a matter of:
Remove caliper and caliper bracket, remove disc screw remove disc, clean hub, new disc, new pads reinstall and bleed? Any other tricks?
I'm thinking of doing the bearings at the same time but it seems like a fairly involved job and I don't have any of the tools...
Any advice appreciated.
Also, have a weird problem where the front left horizontal control arm bolt keeps loosening off after about 100 or 200ks and which means I start to get movement in the steering wheel under acceleration. Any ideas why this would be happening? I had loctite on it but that didnt seem to help. Might try and pull it out and regrease and reinstall but I can't see how it is just loosening off itself!! Definitely torqued it to spec.
Cheers,
Max
Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
