Results 1 to 10 of 11
Thread: What size tyres on your VR6?
    Sep 2006
    I currently have 205/45R16 sized tyres, but am soon to be in need of new ones and have come across a cheap set of 225/40R16. Is anyone running 225s on their VR? Do you think they will be too wide for a 6.5" rim? Do you think they will rub?
    Jul 2007
    Canberra
    I reckon you'd need to get the lips rolled if its lowered. Mine is lowered and running 205/40/17's, rubs when I have passengers in the back but not badly, 225 is a fair amount wider though.
    Forever blowing bubbles.
    May 2006
    Maybe worse than rubbing they'll distort the sidewalls reducing the effective strength in the sidewall. You'll get more movement of the tyre across the rim so the car will not change direction as quickly. Since you would be going up two tyre sizes on the same rim width the sidewall characteristics of the tyre may also prevent them from seating correctly on the rims giving some balance problems.
    It will depend a bit on the characteristics of the tyre how much these effects will bother you in normal driving.
    Jan 2007
    I have 205/45/16's on a 7 inch rim... They don't rub even with people in the back, but then again I'm only sitting on a 38mm drop. Yeah 225's would need a rolled arch and specific supension to be honest, and 6.5 inch is too small for it.
    For a 225 most people have a 7 inch plus tire, closer to 7.5 inch
    You could always try it, and if you get away it with i'm doing it next ! My wheels aren't dish anyway, 0 offset... errghhh...
    Point Cook, Vic
    a 225 tyre should go on a 6.5 rim no worries. Look up the specs of the tyre on the manufacturers website. They will usually tell u the min and max width rim the tyre is designed for.
    I think 225 will be pushing it though. What is the offset of your rims?
    Sep 2006
    I have 215' s on back and 205's on front
    They all rub
    I wouldn't go any wider than 205
    MODS- TOO MANY
    Feb 2007
    Perth, WA
    205/45R26 on a 16x7.5"
    Works well
    Sep 2006
    Australia?
    I have 215/15/40 rubbing though with adaptors 225 is pushing the extreme barrier though!
    Quote Originally Posted by vwthunder View Post
    They all rub
    Dec 2006
    Kilsyth, VIC
    I'm running 215/45/R16 with no issues, but then I'm currently running stock hight.
    Sep 2006
    Thanks for the replies guys. Interesting to hear that some of you get rubbing with 205s, I have loads of space. Manufacturer says that they will fit onto a 6.5 rim, but 7 or 7.5 is recommended
