loon wake up , dblcab talk to loon he'll set u up
Hi Guys....a quick question (or 2)...my daughters 96 mk3 has shat the auto gearbox.............
1. Are all mk3 & mk 4 auto gearboxes interchangeable?
2. What is her cheapest best option?
Regards....Doublecab
to answer the question 96 models are not interchangable with mk4 golf...how many k's has the 96 box done? what is the reason for it to**** itself..what does it do in the change? has it lost drive ? as these box's display symptoms that are not always a worst case senerio.,..has a VAG 1552 or similar been hooked up to read the fault? only trying to help as a mis diagnosis may cost you ! cheers steve
Hi..according to the mechanic...the gearbox radiater/cooler coroded and allowed coolant to enter the gearbox which caused it to malfunction.....he then drained the residue/sludge and obtained a 2nd hand radiator/cooler and after adding new auto gearbox fluid and fitting the new gearbox cooler/radiator he was hoping it was not 'f**ked.....however according to him it is 'f**ked".....has done approx 160ks.Originally Posted by 20v kit car
The gearbox went into 2nd gear 'limp home mode' prior to the mechanic making his diagnosis.
Does this help ??
I`ve got an auto box from a 80,000km 1995 car that had a front end shunt. The car was perfect prior to the accident, I even drove it home. Yours for $500. 0423 051737 Cheers
Cheap fix that.
Go for it.
As usual its the servicing that is the cause as generally VW trans are pretty sturdy.
Thaks man, I reckon its a bargain and only cos I have no place for autos in my life. They cost $2000 from the wreckers.
Mat your g/box is cheap ..they are worth a lot more ...but to answer the prob...water in a auto is bad news..survival rate is low ....but the electronics of the shift need to be reset this is done via a dia system VAG style...so there is still a climmer of hope but a $500 bucks safer and less hassel to go with mat...again the auto will needx to be adapted to the ecu vai the VW system 1552/1551 or VAS..cheers hope this helps ..call me on more clarification cheers steve 0400356057
Oh, Jeez... I'm glad I have a '78 MANUAL diesel!
I also have the electronic wiring loom and computer for the auto if that helps![]()
