You might have a stuck thermostat. Check the hoses coming into and going out of your radiator, the ones going in should be hot and the ones coming out should be cooler...
hey guys, mark 3 is boiling/pushing water out of the overflow. io have found that the thermo fans arent working...would this cause this??
any other possible problems??
thanks
Or a non working waterpump also the fan ecu/fan switch could be faulty
Euro Revolution - eurorevolution@live.com.au
Importing Quality Performance and Spare parts for Audi & Watercooled VW's
New website almost up and running ... http://eurorevolution.webs.com/index.htm
Courtney
I had my thermo fans stop working, turned out the connector to the fans had just vibrated loose and so they simply werent plugged in. check simple things like that first
Sent from my HTC Wildfire using Tapatalk
Possible that the radiator could be partially blocked as well. Sort out the thermo fan situation and go from there![]()
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
