Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: VWwA Used Car Guides (Type 1H) Golf 1991-1998 CL, GL, GL TDI, VR6 & Cabriolet
    Jan 2007
    South Australia
    Question VWwA Used Car Guides (Type 1H) Golf 1991-1998 CL, GL, GL TDI, VR6 & Cabriolet
    1993-1998 Golf (Type 1H) 1.8 CL, 2.0 GL, 1.9 GL TDI, 2.8 VR6, Vento & 2.0 Golf Cabriolet
    If you have owned or own one of the models above please state your experience with the Golf negatives and positives .
    Also fill in the below blanks
    example
    Model: Golf GL TDI
    Engine: 1.9 TDI with 66kW
    Year: 1996
    Any Problems ?: tyres fell off
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Apr 2006
    The common ones have happened to me:
    1998
    MK3 Golf CL
    1.8L 66kw
    Window regs!
    Ignition coil
    and thats about it! cheap as chips and a beaut to drive
    VW Golf MK3 1.8L
    Mini Tanks
    Oct 2006
    Ok heres mine:
    1994
    Mk3 Golf GL
    2.0L with 86kw
    Negatives:
    Drivers and passengers side regulator gone
    A/C not cold
    Speedo not working on dash cluster
    Door locks fallen out
    Excessive play in shifter (fixed by Loon!)
    Inner tie rod stuffed
    Latest is suspicion that the thermostat is stuck open
    Positives:
    Cheap to run and had no mechanical problems so far. It gets me from A to B quite well even if it is a bit bumpy but not bad for an everyday car.
    Ive had other concerns but more due to lack of maintenance or poor workmanship to blame.
    Sep 2006
    West Sydney
    Model: Golf GL
    Engine: 2E 2.0L 8V
    Year: 1995
    Any Problems: Window regulators, engine electrical problems (misfires, false starts), door sill rust, small spots of rust in various parts of the body, wiring not organised very well.
    Those are only problems, but I love the car.
    Feb 2007
    1994 Golf GL
    2E 8V
    88kw
    Problems: Window reg (driver side front)
    ignition module
    crack pipe
    other than that, brilliant vehicle to own and drive daily, reliable, and i like the look of both the exterior and especially the interior
    Feb 2007
    Perth, WA
    Mission: Awesome On 4 Wheels
    Model: Golf CL auto
    Engine: 1.8L 66kw
    Year: 1997
    Any Problems: tappet gasket, tie rods, front strut tops, rear drum brakes, can't go any faster than 180km/h
    It had manual wind up window thing so none of that window reg problem
    Besides all that, with the horrible body roll/suspension, I was able to go through corner faster than 1.8l turbo silvia.
    Model: golf
    engine: vr6
    Year: 1994
    Negatives
    *window regulators, 2 windows still taped up.
    * getting into first gear, must go through second gear before first, otherwise a jammed sensation.
    * standard BBS is a bugger to clean.
    * fuel consumption is killing me. Max MAx MAX 400km / tank
    Positives.
    dispite these problem. enjoying every ride.
    Nov 2006
    Central Coast, NSW
    Model: Golf CL
    Engine: 1.8L 67kw
    Year: 1997
    Negatives:
    * Clutch is going - needs replacement
    * gear synchro is going - may need to replaced
    * too much movement in the gear shifter
    * Rear drum brakes were not properly replaced, leaving them working at only 30-40%
    * Starter motor sometimes doesn't kick the engine over and just makes a whizzing noise.
    * Sponge on the right side of the drivers seat is boken, leaving me falling off into the door.
    * Seat back no longer supports any weight and is quite uncomfortable without some kind of support cusion.
    * Steering wheel is cracking - looks ugly
    * Headlights have a newly developed crack in the glass
    * tappet gasket is leaking a bit of oil
    Basically i need a new clutch, new brakes, new seats, a pod filter, a new exhuast system, and window tinting (so maybe i don't need all of those things but hey... )
    Positives:
    * Its a Golf. Nothing beats it.
    * It sounds awesome at 4500rpm+ (even without an exhaust)
    * Its a Golf.
    * I will never buy anything but golfs again.
    Sep 2006
    Banff, Canada
    Model: Golf GL
    Engine: 2E 2.0L 110Hp
    Year: 4/1994
    Problems:
    * Power window regulators
    * Heater Core
    * (Plastic) Water pump
    * Air Conditioner Compressor
    * Broken headlight reflector
    * Gearshift linkages
    * Crank vapor return pipe snapped ($178!!!)
    Despite all the problems though, awesome car. I would still recommend it to anyone...
    Cheers!
    JHN
    Canadian dubs coming to VWwA soon
