they called me the window reg king a barloworld vw ive done at least 300 i can do on golf four under 30 mins in and out
The vw window regulator
The many issues vw caused with plastic components in window regulators the window regulator works with a motor that is known for internally shorting causing this item to be replaced $$$ {fault number 1} bolted to a door skin this motor has splines {plastic splines} so vw can make money on both items when this item chews the splines away therefore charging out a new motor not cheap, defined as wear by vw {fault number 2}
this splines into a regulator the reg consists of an internal winding of wire with a {plastic retainer} that is the common cause of the problems listed above and below as the wire groves into the plastic and makes ridges causing it all to bind up {fault number 3}tensioned up the window brackets that clip onto two side guides brackets commonly {plastic} so when fault 3 binds up it snaps the window brackets which are plastic and at this stage brittle so vw can make money on the replacement of this item then recall item after 2 generations of golf mk3 mk4 {fault number 4 } to put steel brackets hmmm
I dont get why a company that makes such good cars could make such craptacular window regs![]()
i dont understand why some company hasnt re-engineered these things to be reliable and sell them aftermarket. surely ud make a squillion.
Or you'd at least get a group buy from us![]()
I wish I knew you when this happened william!!! pain in the rear to so this job!!! gggggggrrr
So guys, how much am I looking at to have the drivers windows fixed?
How do i know it is the regulator?
Anyone here can do it for me? And how much
cheers
2012 MY12 Octavia RS Wagon
DSG, Black, Sunroof, Leather, HIDs, Michelin PS3.
Golf Loon can probably set you up with a new window regulator.
On the topic of the window regulator, is there a way to say modify the window regulator to advoid theses problems? All of mine are working at the moment, which i am enjoying, but the left rear one only goes up and down in about 5cm incriments when you push/hold the button. Any ideas what that is?
Ive PM'ed GOlf loon.
Just found out the Window down control of Passengers windows from the drivers controls does work either.
The up works.. PAssengers control up and down works.
what could this be ?
Before anyone tries to have at me, I'm merely putting this out there (and I'm sure he will back this fact up) because it should be known.... window regulators bought from Loon are second hand unless otherwise specified, and it is debatable how long they will last. Both mine have since failed.
sortofbigbj, I'm not sure what that problem is but a mate's vr6 has been doing it since he first got it and it hasn't failed. I'd say it's a bit of dodgy wiring somewhere or something...but that's only a guess.
