Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Thread: VW MK3 GOLF 8V TO 16V CONVERSION
    Feb 2006
    Camberwell, Victoria
    Hey guys,
    I have begun the conversion...
    I am taking out a 2.0L 8v multi-point injection 85kw motor, and installing a 2.0L 16v ABF multi-point injection 110kw motor and a stronger gearbox...
    First of all, my reasons for starting the project
    It's known as a crumble box or 020
    Suprisingly, it still drives!
    And goes clunk clunk...
    So, i bought this...
    THANKS CARL!
    and the important DUAL CAMSHAFTS!
    ANd the work begins...
    AND MY ASSISTANTS!
    THANKS!
    (and the crate it came in....)
    Jul 2005
    Newcastle, NSW
    good on you!
    keep the pics coming!
    Aug 2005
    Hey sean - sorry forgot to reply to your last IM about the clutch parts Those prices are crazy, though :!: :!:
    Anyway, on a more positive note, that throttle body in the picture has the Digi 3.1 TPS, so it won't have an immobiliser, which makes things a LOT easier.
    Goodluck with it
    Feb 2006
    Yeah, its from an early mk3 gti...if it did have digi 3.2 i'd have to have the key and transponder thing, or go aftermarket...motec..hehehe...
    Otherwise, Carl provided a full gasket kit with it, which means that when i do the head gasket, i'll get the head crack tested and then ported and polished...
    But because that will happen before it gets running, then i won't be able to do a before and after power test...
    Other mods will be the BMC CDA airbox i already have. Catch can to remove the PCV oil going into the intake, i hate that build up!! And the exhaust will need to be redone as the baffles in my DTM style muffler are broken...
    And when it is running, i will want new cams...
    But the question is....Would there be any performance gains in getting new valves and valve springs while i do the head
    Aug 2005
    Quote Originally Posted by golf3
    Not unless you move up to bigger valves. I did this on my last ABF - it cost so much that I had to sell the car soon afterwards, though The performance gain is massive, though :twisted:
    The ABF lifters from the SEAT dealer are $450 on their own... so by the time you add new springs, retainers, guides and stem seals, the bill gets pretty huge - that's without the charges for the port work
    It's far cheaper and easier to buy an exchange head from one of the Euro or US tuners if you intend to get one rebuilt and ported
    I've read heaps of times that running cams with the stock ABF management throws the lambda reading up sh-t creek. There are a lot of people running a 260 or 268 inlet cam and a stock exhaust cam, so as to keep the exhaust flow down.
    Probably not worth it in the scheme of things. You need big money to get the real gains. The headwork is definately worth it, though
    Feb 2006
    So, I can get the head ported and polished, AND retain the current valves and valve springs...
    I have a friend that got his head crack tested, then polished, probably ported for $400...
    I'm just loving having 2 camshafts!
    Aug 2005
    Yep, you can reuse them, provided they're in good nick. The valve springs are tough as hell too
    400 bucks is pretty damn cheap
    Apr 2006
    Carlton, VIC (HK now)
    Man...n ur old motor is even only how many km?! i hope i had the equipment, time n money to do a conversion. mines kinda tired now
    Feb 2006
    My "old" motor has 86,000kms...
    My parents bought the car NEW!
    Apr 2006
    yep i did remember u mentioned bout that , normally how many k's the engine would stand?? mines 175000 already
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Electrical problems with VW Golf V towbar
    By JandG in forum Mk5 Golf & Jetta
    Last Post: 08-03-2009, 08:50 PM
  3. single wiper conversion on a Mk1 Golf
    By tassie_euro_mk1 in forum Bodywork/Trim & Detailing
    Last Post: 05-10-2006, 08:08 PM
