Results 1 to 3 of 3
Thread: VR6 upper air intake and valve perished
    Hi all, car was stalling at low revs, heard hissing from the valve connevted to the upper intake boot and found it was ripped, same with one end of the boot itself.
    Any tips on where to buy a replacement (in oz preferable) or do you have a spare one you can sell me?
    I've siliconed the offending areas to get it home, but it's a temp fix only
    Cheers!
    Sep 2010
    Southern Highlands NSW
    Give Seb at Euroautomotive a call or search gumtree "Vr6" under parts and it will show up.... be mindful that there are two versions one for the early 12v and one for the later 12v.... if actual boot was intact you could have pulled the pcv out and just run a hose. Do not block off the breather whatever you do
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
    Mar 2014
    Bundoora, Victoria
    I have an actual boot intact and repaired PCV that worked when it was on the car.
    Past - '95 VW Golf MK3 VR6
