Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Vr6 turbo setup help
    Jun 2013
    Northern suburbs, Melbourne, Australia
    What would be the best turbo setup for a 2.8 vr6???
    Mar 2012
    Central Coast, NSW
    Vague question.
    Pretty much every kit available won't fit due to being made for LHD.
    Heaps of info on vortex and vr6oc
    You either want a spa manifold or a custom one made up similar to the eip.
    Management will be your biggest problem. Probably need a standalone ecu and tune due to lack of chips available to our ecu's.
    It's expensive and if you're asking this question probably best do some more research first.
    Jun 2013
    Thanks man appreciate it, I know someone who can do the tune, but what sort of turbo would be suite for a daily? E.g t3 or t4? Would t26 be ok?
    Dec 2008
    Baldivis, WA
    IMO, GT3076 if you gonna be running a stock block. If you were to stroke it then GT3582. You doing headspacer or replacing pistons?
    '81 MK1 Golf GTI
    '15 VW Golf R Wolfie
    Jun 2011
    Lol. In before 50k budgets needed
    3076 is way to small. You'll be on full boost at 2500rpm.
    You'd ideally want a 3582 with a .82a/r or t04e 60-1 with a 1.06a/r. Both will be 3700-4200rpm spool.
    Spa exhaust manifold will be fine.
    Custom dump pipe -> 3" exhaust from a local zorst shop.
    Decent wastegate or buy an internally gated turbo for ease.
    Depending on the money you have, mega squirt-> haltech/lugtronic/adaptronic.
    There's no point running an inter cooler unless you go through the effort of reducing compression.
    "I only post on Facebook if I know i am going to get likes" - M
    Aug 2007
    Quote Originally Posted by MisterMk3nasra View Post
    You need to tell us what you what to use the for first. Fast street car, track/drag car or a combination of both. All will have a different setup
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
    Mar 2009
    Wagga Wagga
    Lol what? Even more reason to run an intercooler if you aren't going to decompress the engine. Especially in Australia's hot climate.
    Setup depends on three things:
    How fast you want to go.
    How reliable you want it to be.
    How much you want to spend.
    If you plan on leaving the motor stock, 3076 will be all you will want. Good low end punch but will run out of puff up top. Up to 500hp atw.
    Next will be the GT3582. A bit more lag, but monster mid range torque. Good for 700hp atw.
    Of course this is only the Garret branded turbos. There is also your precision turbos etc.
    My motto is: Do it once, do it properly.
    At least rebuild a stock engine, they are getting high in the KM's nowadays. But if you have the engine apart, you may as well decompress it. If you are decompressing it, you may as well go the bigger turbo. Haha the list goes on.
    Don't forget to budget for gearbox, suspension, brakes, wheels, Tyres, mounts.
    Good luck!
    Jun 2011
    You can only run so much boost without decomp. It's not worth the hassle of fabbing up an effective intercooler for the 2 psi more you'll get with a cooler charge.
    Mar 2009
    Wagga Wagga
    It's not about extra psi, it's about making the intake temperature as cool as possible. VR6's already run hot without running a hot air pump straight into the intake. Hot intake = **** performance, detonation and eventually a big paper weight.
    The only time I wouldn't use an inter cooler would be if it was only going to be running on methanol or e85, and even then, why wouldn't you?
    Jun 2011
    With more boost the intake air gets hotter..
