Results 1 to 5 of 5
Thread: VR6 timing belt/Chain??
    Jan 2007
    Quakers Hill, Sydney
    Hi Guys
    Looking at a 95 VR6.
    Just wondering as I have read thay have a chain, but also have read the car has a belt?
    Which is it & how often if ever (chain) does it need to be replaced?
    Is this a big job if so & what sort of $ are you up for??
    Mark
    Camden, Sydney
    They have a serpentine belt to run all the acessories, which is not that hard to change.
    Timing chains and guides rarely get changed in these cars, it is an engine out job.
    Point Cook, Vic
    The timing chain guides are made of plastic and do wear out. I think its usually around the 200,000km mark. Usually its and idea to do them when the clutch gets done. a pretty expensive job as there isnt much room under the bonnet of a vr6. I was quoted 8 hours labour to do the job.
    Being an interference engine u dont want to let it go if the chains do start making noise tho. can get very expensive.
    FOLLOW US ON FACEBOOK
    Jan 2007
    Thanx guys
    Dont have one as yet but really handy to know this B4 shopping
    Oct 2005
    the serp belt needs changing at about 80K - if it is in bad condition it will be crazed and cracked
    \'95 Golf VR6
Similar Threads
  1. 60k or 100k for timing belt?
    By BL33SU in forum Passat (B4 & B5)
    Last Post: 02-05-2007, 10:54 PM
  2. timing belt on a 2001 mark 4
    By Rod_H in forum Mk4 Golf & Bora and New Beetle
    Last Post: 23-10-2006, 08:49 PM
  3. Injector Pump Leak and movement - Main Shaft
    By hvellacott in forum Diesels
    Last Post: 28-09-2006, 07:20 PM
  4. timing belt
    By deemoE36 in forum Mk3 Golf & Vento
    Last Post: 25-06-2006, 08:24 PM
