Results 1 to 8 of 8
Thread: VR6 ticking noise??
    Ipswich
    VR6 ticking noise??
    Hey guys i have done some work over the time to this car and it seems to be one problem after another. i have change and swap a few things such as leads, hoses, plugs, relays, lights the list goes on... anyway the engine has always made a ticking noise almost sounding like a diesel and its kind of annoying not knowing what it is. i will link a video of another vr6 that sounds pretty much identical as mine however the noise is not as noticeable when its not idling. if anyone knows what is causing it and how to fix it/ what new parts i would need would be great.
    Cheers.
    https://www.youtube.com/watch?v=5CZ6-c_LpBc
    Ipswich
    Thought i would share a picture of my engine.
    Attached Thumbnails Attached Thumbnails VR6 ticking noise??-11125285_851678648202955_179943302_n-jpg
    nt
    Lifters?
    Jun 2011
    Tough one.
    Usually would say lifters.
    But i had a similar noise after having timing chains done and it was the tensioner. Oil thinned out with heat and the tensioner would lose pressure and slacken the chains.
    Ipswich
    yea i have read some other forums saying it could be anything from lifters to the oil guess its just going to be trial and error.
    Jun 2011
    Well. If it happens when cold and hot lifters.
    If it happens when hot tensioner
    if it gets real loud at 2000-2500rpm and quitens off a little with rpm, hot and cold couldbe chains
    Ipswich
    When its hot its not as noticeable and when driving the engine sounds fine so will probably start with tensioners
    Cheers.
    Sep 2014
    Mine does the same thing 😪
    Ive just learnt to live with it.....
