Results 1 to 10 of 10
Thread: vr6 temp
    Jan 2010
    vic/werribee
    vr6 temp
    ey guys my vr6 coolant water is very hot i take it its not normal? but its on the right level
    euro vr6
    Apr 2009
    Newcastle NSW
    Not necessarily, Coolant at full temp is pretty close to boiling point.
    Plus the system is pressureised so that raises the boiling point of the coolant, thus the coolant gets even hotter.
    So I would say its pretty normal.
    Thats why there is warnings on radiator caps.
    Point Cook, Vic
    coolant water gets hot. whats the temp gauge say?
    FOLLOW US ON FACEBOOK
    Jan 2010
    vic/werribee
    its on half but red tep light keeps flashing
    euro vr6
    Point Cook, Vic
    did you check the coolant level?
    Jan 2010
    vic/werribee
    yeh its on the right level
    euro vr6
    Jan 2010
    Rockingham, WA
    Hi, Mine did the same, turned out that I had a small leak in the system
    Jan 2010
    vic/werribee
    whats the mixin ratio for coolant for a vr6 cheers
    euro vr6
    Aug 2009
    ACT
    Quote Originally Posted by terps View Post
    50/50 according to the bentley manual
    Aug 2008
    Bondi, NSW
    Check your auxilliary water pump.
    Mine failed and jammed up and caused overheating.
    You should be able to hear it spinning away with the ignition on and the engine not running.
