Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: VR6 steering
    Nov 2008
    Canberra
    The part name escapes me ...
    But there is this spring loaded thing situated behind the steering wheel, and apparently that has electrical contact with the airbag ...
    I will go and look at my invoice and report back later tonight.
    TassieGTi Guest
    There would be plenty of those around second hand and its not a common problem.
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by MattyT View Post
    Mine does a bit too. I just chalked it up to being something model specific.
    Mine does it too, maybe a model "feature"?
    Dec 2008
    sydney
    Quote Originally Posted by noom View Post
    I recently experienced some roughness in steering. And then one day when I had to do a hard right to get into a parking lot, I felt something break behind the steering wheel, and then my airbag light came on.
    Turned out that this is something of a problem with mk3s and polos ... VW charges heaps for this part. Mine cost me $400 to fix.
    I did plenty of hard rights in it trying to provoke unwated sounds or warning lights but nothing.
    The steering in the one I'm getting is still smooth but heavier turning right.
    If I can't find the problem, then I'll put down as a model "feature".
    Jul 2007
    Rowville Melbourne
    that part that makes the electrical contact for the air bag, and horn and whatnot is the slip ring. you can mess it up by turing your steering wheel with the shaft not connected. so dont do that. but you probably wont so dont worry about that. you'd have to be doing something weird to do that i would think.
    maybe your right handed and your right arm is stronger turning left...? i dont know, i have no input with the left and right turn thing im just talking crap. good luck though
    -steve
    Sep 2006
    Parkinson / Brisbane
    im strangely the same also, though not excesive and hardly worth me trying to analyse and fix . . .
    Dec 2007
    Ermington, Sydney
    Can I say I have a bit of steering weirdness also? hehehe....I think mine could be a driveshaft problem though because I've had a bit of potential driveshaft issues recently which I'll be checking out soon. My car is easier to steer left.
    Dec 2008
    sydney
    I had the power steering fluid flushed and it improved it.
    I was going to change the rack but there are no leaks or noises so I left it alone.
    Driveshafts are fine too.
