Results 1 to 10 of 10
Thread: vr6 speedo
    aldinga, sa
    Question vr6 speedo
    bought my first vr6 fitted adjustable konis eibach springs and gave whole car tidy up in readiness for daily driving love the car but two days after i starting using it the speedo/tacho stopped working tacho flickers at 0 revs speedo inoperable occasionaly both will work particularly after cold weather has anyone had such experience with a vr6 before?
    Peregian Beach
    I had that happen once on my VR6 after the battery had been charged while in the car. If you have the PIN for your radio I would suggest that you try disconnecting the battery for a few minutes and then re connecting it. It fixed mine so it will cost you nothing to try.
    Sep 2006
    West Sydney
    Welcome to VWW timo. First of all, congrats on your VR6 purchase. It's a cracker of a car I'd bet
    Where abouts are you based? It'd be good if you can adjust your user options so you can display your location. Also, most posts should go in the General Chat section - you'll get more views there than here!
    Mate, if you're located in the Sydney area, give Matt at CamdenGTI a call - 0423051737. He should be able to help you out with your clocks, and if still doesn't work, he should have spare ones. He's located in Campbelltown by the way.
    Feb 2006
    I think I have one sitting somewhere in garage.
    Only problem less then 100 000 kms
    Oli
    aldinga, sa
    have had battery disconnected since then and hasn't done a thing! thanks for the thought mate anyway coz i think theres something going on with my radio too you can disconnect battery and don't need any code to get radio working again...radio works with ignition turned off, is that normal for a volksvagen?
    Quote Originally Posted by timo View Post
    Hey welcome to forum. I had the same issue the the OEM stero, I was supprised at that too.
    Dec 2006
    Kilsyth, VIC
    You mean with the key in right? The car's "accessories" function appears to be when the key is in rather than another notch on the barrel.
    aldinga, sa
    Quote Originally Posted by The_Hawk View Post
    radio works whenever don't have to have key in at all luv pic of your golf too looks orsum wish mine was black is maroon though or a hot chilli red one
    Jul 2007
    Constitution Hill
    you'll need to replace your odometer. the same thing happened to mine.
    Jul 2007
    Constitution Hill
    Quote Originally Posted by Oli View Post
    Oli
    I bought that one off you oli. are you talking about the same one?
