Funny mine slot the other way I think the stock ones are OK and its not needed unless your going to race it really but Brembos like Alex K11LZ's ones are the go.
I think its time to get new rotors on the Dog.
Has anyone put slotted & drilled rotors on their VR6? What brand did you use and what are they worth? I've seen some in UK mags called black diamond with a black finish, they look fantastic.
Pre '96 had smaller brakes too on the front... 280mm I think which is what I need.
existing front brakes...
Lex.
1983 Lotus Esprit Turbo
2013 VW Golf MkVI Cab
Looking for a blue MkIV R32.....
Brembo & AP Racing both make kits for the VR6.
I have no idea of cost for either but you can lay a solid bet it will be A LOT.
I plan on upgrading my brakes since I think the VR6 needs more stopping power for anything more then lesuirely pottering round.
That black coating lasts until you get to the end of the street. I have had BD disks in the past and they lasted really well, that was on a MK1 with an upgrade in size to 270mm so not really worked hard on the road. They did take a beating at the track though.
If ur gonna go drilled and slotted, they eat away at ur brake pads faster than normal. Like mk3vr6 said unless u do track days or sumthing, the stock slotted ones should do fine![]()
Im confused about the VR6 brakes. The early ones definatly had the 280mm, and late ones definatly had 288mm, but im told i should have 280mm from my build date, but the VIN says i have a series 2 and there for i have the 288's
Im confused.
Ive looked at a few US parts sites and you can buy a 288mm brembo drilled disk that looks fantastic, with the proper recesed holes of the brembo.
When I remember to, im just going to get a tape measure and see how big mine are. None of this VIN# confusery!
280mm disks are 22mm thick and the 288s are 28mm IIRC. The calipers are a fair bit bigger too.
288s are 25mm thick
You're right Tim 25, 28 didn't ring a bell now I know why.
