Results 1 to 10 of 12
Thread: VR6 shifter bushings
    Nov 2008
    Canberra
    Hi there,
    I sometimes have trouble finding first gear, and it appears that it could be the gear bushings that have worn down.
    However, looking at ebay, the shifter kits all say that its not for VR6 which have a cable shifter. What does that mean?
    Also does anyone have a short shifter kit installed? Is this costly?
    Dec 2007
    Ermington, Sydney
    Our VR6's ARE () cable shift. But... the linkages you'll find on eBay aren't for the VR6.
    Shortshifters vary in price I think; everyone who buys them says they're worth it, and I think they're around the $150-250 mark, someone correct me if I'm wrong? Depends which model you get etc
    Camden, Sydney
    Quote Originally Posted by Mrk_Mickey View Post
    Our VR6's aren't cable shift. Anything cable-shift won't fit our cars, ie the linkages you'll find on eBay aren't for the VR6.
    What planet are you on Mickey?
    All VR6s are cable shift.
    The rods you find on ebay for a 2L will not fit.
    You can adjust the shift linkage on a vr6, or there is something worn.
    A short shift will not fix this problem, it will probably make it worse.
    Dec 2007
    Ermington, Sydney
    ARGH my bad. not cable CLUTCH.
    Feb 2007
    I think I have a similar problem, only on my 2.0. Is it a shift linkage bush or something?
    Mk3.Mk4.Mk1
    My Mk1 Project
    Nov 2008
    Canberra
    Do you mean that the shift linkage is adjustable without the need to replace any parts? Sorry I have no concept of what a cable shift means.
    thanks for the heads up on a short shifter.
    Jul 2007
    Canberra
    Quote Originally Posted by madglf3 View Post
    I have some shifter bushing kits which were sold to me as VR6 items but they ended up being rod shift bushings, if you want one let me know. That applies to everyone else too, I have 2 of these kits PM me
    Forever blowing bubbles.
    Quote Originally Posted by noom View Post
    I always assumed it is an gearbox mount problem... As OEM gearbox mount sagged over time causing gearbox displacement, resulting in accurate shifting ... ???
    I think most mk3 has that problem.. I over come the problem by slamming it into second before first, always helps.
    Also short shifter made no difference, but worst when I installed the side to side reduction.
    Will keep you updated once I install my BFI mounts in the coming week.
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by Soundofav6 View Post
    I over come the problem by slamming it into second before first, always helps. .
    That's what I do as well. I used to hate my gearbox but I know how to make it obey me now
    Camden, Sydney
    2L is a rod shift and probably needs a bushing. This is quite different to the VR6 scenario and has been discussed on other threads on here.
